bizhub601 error c-2804
  • stratos
    • 17
    Hi everybody!
    after PM (500.000) the machine start giving errors like c-2801,c-2803,c-2804
    The machine can only work with the cleaning blade to the release position OFF
    can anybody help?
  • Desert Rat
    • May 2008
    • 1089
    stratos,
    Please tell us what it does with the blade on the drum? I had a 600 at one time and some of these machines
    are prone to "blade flip". You could try re-powdering the blade and drum. After I powder a drum and blade
    I will turn the drum opposite of the way it normally turns to prime the blade. Usually about a half a turn.
    Also you may try using methusala powder. This stuff is really good and you will be able to notice a difference
    in the resistance felt when turning the drum in the correct direction.
    Hope that helps
    DR
    • stratos
      • 17
      when the blade is on it stacks the paper in front of the fuser
