staples on a few of set imagistics 9982 fs-111
  • pudgi300
    • Sep 2007
    • 193
    [Misc] staples on a few of set imagistics 9982 fs-111
    Hi,
    I have imagistics dl850 with 9982. When doing a staple job upper left. Sometimes the whole set will staple and other times it may staple only 2 or 3 and stack the rest on top of the stapled copies. Then it will send the copies to the exit. Is this a firmware or some kind of noise problem. The only thing i have done so far is clean all the sensors. Don,t really know where to start on this one. I may try to switch staplers but kind of doubt that is the problem. Maybe someone has seen this one before. Thanks for any help.
    Later Pudgi300
  • pudgi300
    • Sep 2007
    • 193
    Went back in today and swapped the staplers and ran 30 sets of eight copies. It worked fine. Before this test i ran 5 set and 2 of them were bad. Still not sure what happen but swapping the staplers seems to have fixed the problem. Will report back if this doesn't resolve the problem.
    Later Pudgi300
    • kronical
      Kronic Copier Ninja
      • Nov 2009
      • 230
      Clear a sheet of staples from the cartridge and make sure there is no loose staples or debris inside the stapler unit.
