bizhub c351 low quality grey (black)
  • tasta
    • Aug 2025
    Hi,
    everything that is not 100% black so it's grey has a lot of lines that cross only the darker grey - please see the scanned paper. This is printed on plain paper - on thick paper the problem is more obvious.The machine has 230000 copies made but i just changed the belt and the black drum (not the entire black UI only the drum) and the problem persist. I cleaned the black LED but no improvement after that. I'm running out of ideas so please help me. Thanks.
    Updates. I decrease the density on halftone pattern in service mode and it seems that lines appear on colors too. Also i attached another scan on 250 g thick 3 paper where you can see how bad the black is.
  • mo0651
    • 1054
    Looks like a charge wire streak. Have you cleaned the main charge?
    • tasta
      Hi, thank you for your post. To be honest i do not know where the charge wire is but i will study this and i will clean this. I will be back with results. Also in the upper right part (portret position) is a much darker zone. Can this be from fusing unit?
      • stryker3k
        • Jan 2011
        • 11
        If you have only changed the drum, then i would change the entire IU. The dev in the IU is prolly stuffed. I have never changed anything but the entire IU, but that is KM's policy.
        • tasta
          Hi, i already test the machine with another black IU and the problem persist so is not from dev.
          • stryker3k
            • Jan 2011
            • 11
            Considering you have done Belt, IU, and cleaned the LED, it could be the LED itself or even the HV. When you cleaned the LED, did you use a moist cloth/cleaner strip? Dry doesnt always clean it properly.
            I just noticed that you say that those lines show up on colours too? If that is so, I would say belt (or possibly HV but that is unlikely). Did you test it with a new belt? or just a used one? Coz i cant see the fuser causing banding like that.
            • tasta
              Hi, the belt has only 500 on counter and it looks perfect. The old one had some banding on it but the current one is perfect so i think that is not the transfer belt. In the colour tests the banding are almost invisible and the color of lines is fade white - opossite to the black tests where the lines are black ( see attachements on first post ). I really do not know what else i can do.... The led was cleaned with a dry pad but because i spotted the banding on colors too is not the led. Maybe the electronic part of the led's?
              • stryker3k
                • Jan 2011
                • 11
                Hard to say, you have replaced everything except for the LED.the white lines on the colours might be a seperate problem altogether. I am thinking the K LED is faulty going by what has been replaced. I have never had to replace an LED on that model, but there is always a first time i guess. I would still try cleaning the LED with a moist cleaning pad because it does make a dramatic difference over a dry one (even thought it is usually shadowing on the black that you clean the LED for.)
                • tasta
                  Hi, i've cleaned the LED with moist pad and nothing has changed. I'm waiting for another IU (maybe it was a sad coincidence with the one i already test the machine) and i will see the results. Thank you for your advices.
