Konica 7150
  • Luther
    • May 2006
    • 682
    Konica 7150
    Anyone have the procedure for turning on the ECM(ELECTRONIC COPY MONITOR) for the konica 7150/7060 , any help would be appreciated
  • copyguy5
    Konica Ecm Configuration
    The ECM (Electronic Copy Monitor) is well covered in the Konica 7155/7165 User Guide. This can be found at:
    Index of /protectedmembers/111514/Konica7155_7165_Force65manuals/pdf/urg
    Good Luck
    COPYGUY5
    • Luther
      • May 2006
      • 682
      thanks copyguy i have the user guide but i need to turn it on in th dip sw mode 1st i think
      • dbrownlee
        • Sep 2005
        • 197
        Actually, I think you have to turn in on in Key-op mode, not service mode. I'll check in a bit to make sure, but I'm pretty confident in that.
        GO TIGERS!!
        • copyguy5
          Konica 7155 Service Manuals
          You can download the service manual from:
          Index of /protectedmembers/111514/Konica7155_7165_Force65manuals/pdf/sm
          Search the Adobe doc for "25mode", "36mode" etc.
          Hope this helps
          COPYGUY5
          • bgbas
            • Feb 2007
            • 60
            Yes it is in the key op mode. The default password should be "00000000" thats eight zeros.
            • Luther
              • May 2006
              • 682
              Thanks guys it's been awhile since i had to turn on that feature
              • etsmultan
                • Apr 2007
                • 131
                its a good try
