Hi All
Recently took delivery of a C5501 and still trying to find my way around.
When printing from the bypass tray on thick (100lb cover gloss card), if I re-feed the same card through to print the second side and it contains the same colour, often the colour is not the same. I know that when duplexing machines are designed to make an adjustment for this (or so I am told), what about when manually duplexing? Is there some other setting I should be using especially if using stock that cannot be duplexed?
Or is this just a issue with digital printing two sides?
Any help would be appreciated.
Many thanks
Artichap
Many thanks
Artichap
