Bizhub c452 Help - Need to reset C+Y Imaging units
  • diamondian
    • May 2009
    • 26
    How do i reset the C+Y Imaging units,
    Been through all of the menu's in service mode (with the door open) but can't seem to find how to reset them.
    Please help, urgent job needed to deliver.
  • mabawser
    Tech
    • Sep 2009
    • 121
    I might be talking a load of crap but do you not need to either replace the units or replace the chip in them to reset. There isnt a manual reset.......
    • emujo
      • Jun 2009
      • 3009
      Color I'Us, K drum and developer shoud reset themselves when a new unit is installed. You can't take a unit that has been placed in another MFP and use it to reset a 2nd one. Fuser and X-fer belt are reset through the sevice mode with door open. I believe there are some chip resetters out there, but I have never investigated it
      • owencom
        • 10
        New IU chips are available at Konica Minolta C452 Toner Refills, Toner cartridges, Drum Units, Trans
        • jarwil
          • Jun 2009
          • 61
          no manual reset for imaging units, fusers or itbs in these machines.
          Imaging units reset by chips and fusers and itbs reset by blown fuse when installed and turned on for first time.
          Can make machine not stop when imaging units need to be replaced. Machine wont stop but message still appears that they need replacing.
          • pepper38_cnd
            Field Service Manager
            • Aug 2005
            • 1075
            Buy a chip resetter, and save $$$$$.
            Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
            Now into Ip TV KODI Boxes
            • emujo
              • Jun 2009
              • 3009
              Take a look at the model, you may be thinking of the C650 series, but you are incorrect regarding the C652 series, the fuser and x-fer belt are not fused, and you cannot set them up to run past the service life. They will crunch to a stop. Emujo
              • krazeekidz3
                • 48
                You can make the IU's continue to run until you decide to replace them; on, possibly all, of the current color models of Konica Minolta. The machine will continue to ask for the IUs, until you upgrade the firmware. But you can set the machine to "NO STOP" in service mode. I've done it on C252, C350, C451, C550, C353, C253. As long as the customer doesn't mind the message. Then when you start to see lots of P-22's and P-21's in the warning history, time is almost up!!! The IUs will go about twice the normal life!!! After the firmware has been installed, the message on the control panel disappears (AFTER you change the setting in the software switch setting mode.) The exact procedure is under proformance inhancements in the technical bulletins area of the KMBS website.
