Command Workstation print issue
  • jasonofx
    Service Tech
    • Nov 2006
    • 64
    A customer has an intermittently recurring issue with print jobs. When he sends multiple sets of a print job with a lot of pages (100), it shows in cws that there are 10 sets to print, but when it gets finished with 1 set, it stops printing and moves the job into the finished queue. It is a pdf, and is not a large document. File size seems to have nothing to do with the problem, he can print a 10 page file that's 100mb, and do 10 sets of it fine. But this file is only 14 mb, 100 pages, and it will only print 1 set at a time. We tried to "process and hold" at cws and then print, but we got the same results. The next thing I will try is to "print as image" in the print dialogue box. Just wanted to throw this out in case any of you have come across something similar and have any suggestions.
  • Hemlock
    • 432
    Which version of CommandWorkstation?
    โ€œAnti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'โ€ (Isaac Asimov)
    • mrwho
      Major Asshole!
      • 4299
      Is the Fiery fully patched and using the latest drivers and CWS?
      Mascan42
      Ibid
      • jasonofx
        Service Tech
        • Nov 2006
        • 64
        I will check both of those tomorrow or the next day and get back to you, thanks for the replies!
        • Stirton.M
          All things Konica Minolta
          • Oct 2009
          • 1804
          The problem is likely the Fiery itself or the driver/OS. Command Workstation is just a portal to the Fiery. The problem presents itself when the user prints from their computer.
          What is the Fiery and the printer models? I'm with mrwho on the patches and drivers being used.
          "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
          ---Groucho Marx
          Please do not PM me for questions related to Konica Minolta hardware.
          I will not answer requests or questions there.
          Please ask in the KM forum for the benefit of others to see the question and give their input.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            I couldn't agree more on having everything patched and up to current specs.
            One trick to try, though. Rather than printing to the Fiery and using CWS to change parameters and/or reprint, use CWS to import the PDF file directly - that way you'll be eliminating the user's PC and print driver from the equation.
            โ€œI think you should treat good friends like a fine wine. Thatโ€™s why I keep mine locked up in the basement.โ€ - Tim Hawkins
            • jasonofx
              Service Tech
              • Nov 2006
              • 64
              Using CWS 5, (5.0.1.12), Fiery is using EFI Fiery System 9 Version 3.0. I'll have to check Konica to see if these are the most current, not sure if it's ever been patched, (probably not), so i'll probably start there.
              Will also bypass the computer and print driver by importing into CWS directly. This issue is intermittent, and the customer does not repeatedly want to waste 100 prints, so we'll continue testing as the need arises, but I'll for sure get the Fiery up to the latest system software and fully patched.
              It is a bizhub PRO C6501-Fiery Pro 80
              • studioyumi
                Re: Command Workstation print issue
                Hello,
                I have the same issues with printing PDF files. Only one copy wil be printed. I use CWS 5.3 with a KM C253 and a fiery IC0-409. Does anyone have a solution for this problem
                • empiru
                  • Feb 2011
                  • 229
                  Well, by my logic, if you say he can print it another document with no problems, then it's clearly an issue with the document, not with the machine... Anyway, did you try with "Process and Hold" and then set the number of copies directly in the workstation?
                  I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
                  • studioyumi
                    The problem only exists with PDF files.
                    • empiru
                      • Feb 2011
                      • 229
                      I'm pretty sure you're an end user. My post was for the guy that started this thread, that's why I quoted him. For you, I have something written in my signature! Have a nice day!
                      PS: nothing personal.
                      • RRodgers
                        • Jun 2009
                        • 1947
                        Uncheck collate, and set the number of sets you want in the driver not the print window.
                        • rangertech
                          • Jun 2011
                          • 40
                          maybe the problem in application software pdf. have you try create new file multiple page pdf with another pc ?
                          • Ianizer
                            • Jul 2011
                            • 380
                            I have a few questions:
                            Have we isolated the driver yet by importing directly to the Held que, changing the quantity, and printing the job?
                            If not sensitive material, will the customer supply a problem PDF to the technician on a thumbdrive for t'shooting via technician's laptop and resident driver, again isolating the driver/network/file/application?
                            Are we using the PS or the PCL driver?
                            -I
                            My name Peggy.
                            You got problem?
                            • jasonofx
                              Service Tech
                              • Nov 2006
                              • 64
                              -I
                              Now that this thread is revived, this issue has been resolved. Another IT guy for my company had to go to this customer for another reason, and he figured this one out while he was there. He told me what solved it, but it's been so long I can't remember exactly. I think he had to re-install CWS and the print driver on the user's pc, they had updated from OSX10.5 to 10.6 without telling us. Just wanted to follow up so you guys didn't think I had asked for help then jumped ship
