Hi,we mainly service kyocera brands but we are looking at this konica minolta c35 model.Anybody got any opinions good or bad?would be interested to get some feedback,also do the cartridges,drum etc,go the distance or are they prone to failure?had a quick scan through the service manual and it rates the toner for continuous printing.Is this an issue for you?.Thanks in advance..
Opinions on bizhub C35
Tags: b/w, bizhub, bizhub c35, bypass tray, copyi, konica, konica minolta, kyocera, minolta, printing, pro, scan, service manual, toner
Got about 20 of these in our area..so far no complaints..front door is a little weak and had to replace 2 so far. Very easy to set up and get copying/printing/scanning. I think the standard paper capacity is a little low and for some reason the bypass tray is "Tray 1". It would be nice if the color button could be locked out w/o needing department codes (service mode setting...). This is the perfect MFP to replace that worn out HP 5, but not the Toshiba 281C or the KM C350. EmujoIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals.Comment
