konica1120
  • cliffhangers
    • Feb 2010
    • 242
    konica1120
    good day i am having problems with this konica1120 it copy very light when i put ink inside the developer it good bet when i copy like 150 it will get back to it normal lightness please i need your help thanks in advance.
  • mrwho
    Major Asshole!
    • 4299
    You probably need to change the developer and do the L-detection. Could also be a case of wrong toner (that machine shares the same design of the 1015, 1212, 1216 and 2223 - does your customer has other machines that might've caused him to make a mistake when adding toner? I've seen neighbouring schools with different machines exchanging toner between them just because the machines "looked alike").
    Try to add toner in order to make the copy look good and then make the L-detection procedure.
    Mascan42
    Ibid
