c-6500 code on boot-up
  • beetle73
    • Dec 2010
    • 44
    [Error Code] c-6500 code on boot-up
    I'm getting an intermittent c-6708 code on boot-up. It will eventually clear, but will come back the next time the machine is booted up or service mode is exitted.
    I have reseatted all accessible connectors. I have replaced image process board, inverter board, interface board, exposure lamp, scanner h.p sensor. It has version 60 firmware.
    The exposure lamp flashes and then the code appears.
    Anyone have any ideas besides replacing cct boards!
  • gang1110
    • May 2010
    • 43
    PROBABLE CAUSES:
    1.
    ICP2 on the IFB (Interface Board) is OPEN.
    Verify that ICP2 is OPEN and replace the IFB (p/n A03U H100 01) if necessary.
    2.
    ICP(s) OPEN on the IPB (Image Processing Board).
    Verify OPEN ICP(s) and, if so, replace the IPB
    3.
    Failed exposure lamp or Inverter board. At power up the exposure lamp moves to the left to perform shading correction, but the lamp
    never lights.
    Replace Exposure Lamp (p/n A03U M301 01) or Inverter Board (p/n A03U M405 00) as necessary.
    4.
    ICP1 or ICP2 is OPEN on the CCD.
    Verify that ICP1 or ICP2 is OPEN and replace the CCD (p/n A03U A290 00) if necessary.
    5.
    The CCD wiring is poorly connected or damaged.
    Reseat connection ribbon cable (p/n A03U N133 00) on the CCD unit and IPB. Inspect for damage and replace if necessary.
    • beetle73
      • Dec 2010
      • 44
      Thx for the reply but the code does reset and the machine will work for a while so the problem is not an component on a cct board. Reseating the ribbon cable to and from the ccd also didn't help
      • Christian_W
        Support Specialist
        • Jan 2011
        • 33
        It is possible that the CCD Unit is damaged. Last week I had a system with the same error, but the error code comes every time we switch the system on.
        At this system the connector from the ribbon cable was broken.
        • seniortech
          • Dec 2007
          • 180
          Yes check the ribbon cable, it is very easily broken...
          • Christian_W
            Support Specialist
            • Jan 2011
            • 33
            Hello seniortech,
            you can try to cut the cable a little bit, but I think it is better to change the cable
            regards
            Christian
            • beetle73
              • Dec 2010
              • 44
              c-6500 code
              The ribbon cable appears fine. No visible breaks. I tried trimming both ends but no luck.
              • bigdcopy
                • Dec 2010
                • 70
                I just had the same problem
                change the ribbon cable
