LDAP lookups - "Failed to resolve name in DNS server" <- C352s
  • DeLF
    • Aug 2025
    [Error Code] LDAP lookups - "Failed to resolve name in DNS server" <- C352s
    Hi all,
    We have several C352 printers and we need to authenticate them against AD. I have spent a long time testing and configuring LDAP to do lookups and each and everytime i click the "Test Connection" button I get the error Failed to resolve name in DNS server.
    I know my DNS setting are correct and both forward and reverse maps resolve perfectly. (The printer has perfect LAN connectivity).
    I am suspecting a firmware bug ?
    Can anyone suggest how to debug this further ? (konica tools ?)
    This is the current firmware dump (i have no clue what the latest is?)
    MFP Controller BOOT Program
    9J06-1E00-G00-01-000(00)
    MFP Controller SubSet Program
    9J06-1F00-G00-02-000(00)
    MFP Controller
    9J06-0100-G00-I8-000(00)
    Operation PANEL Message Data
    9J06-8100-G00-I2-008
    FAX Board Controller1
     FAX Board Controller2
     IR
    9J06-0023-G00-10-000
    PRT
    9J06-0050-G00-20-000
    LPH
     ADF
    9J07-0024-G00-06-000
    Finisher
    9J08-0071-G00-06-000
    System Controller
    9J06-1000-G00-I8-000(00)
    Printer Controller
    9J06-3000-G00-43-000(00)
    Printer Controller-Font
    9J06-3F00-G00-14-000(00)
    Printer Controller-Demo Page
    4037-3E00-G00-00-000
    MIO
    9J06-5000-G00-63-000(00)
    PSWC
    9J06-5100-G00-34-000(00)
    MIB IF
    9J06-5200-G00-20-000(00)
    IPP IF
    9J06-5300-G00-03-000(00)
    External Controller IF
     TCP/Socket
    9J06-6300-G00-00-000(00)
    Open API
    9J06-7000-G00-86-000(00)
    Operation PANEL
    9J06-8000-G00-E0-000(00)
    CSRC
    9J06-8300-G00-02-000(00)
    PIC
    9J06-8200-G00-07-000
    -Alex
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Maybe this will help?
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • DeLF
      Thanks, but i have tried all possible configuration possibilities and I still get the error Failed to resolve name in DNS server when clicking "check connection".
      Besides resorting to a packet trace are there any other tools you can recommend to get more debug output than "Failed to resolve name in DNS server." on konica printers ?
      -Alex
      • JR2ALTA
        • Feb 2010
        • 2033
        You could try to dump the DNS cache, from what I understand it's harmless and solves a lot of problems.
        But Google it or talk to an IT professional first...
        • Spidula
          Konica Minolta Technician
          • 83
          Latest F/W is K0 for the 352s But I had an LDAP prob with a machine with K0 F/W on. I.T sorted it eventually, but don't know what the fix was!
          • RRodgers
            • Jun 2009
            • 1947
            Last time I had a problem with LDAP it turned out to be the time on the copier was off by more than an hour. CHECK the TIME on the copier.
            • BlueBlazer
              • 25
              Find out what your AD's server IP is and try connecting directly if flushing your DNS cache doesn't resolve the problem. Also double check that the IT department didn't do anything screwy with their AD server like set SSL or something.
              • Stirton.M
                All things Konica Minolta
                • Oct 2009
                • 1804
                "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
                ---Groucho Marx
                Please do not PM me for questions related to Konica Minolta hardware.
                I will not answer requests or questions there.
                Please ask in the KM forum for the benefit of others to see the question and give their input.
