Konica 7020
  • ATSBMCO
    Technical
    • Oct 2007
    • 70
    Konica 7020
    We have a customer with this model and the fault is that it will not drive any of the paper feed system, cassettes or manual by-pass.
    I have checked the gearing system and the only problem I could see was that there is a solenoid that transfers the drive, it is this that has no function, all gears are fine.
    I measured the power to this solenoid and it has none. Does the machine require a reset or does any body out there have any further checks I should do?
  • random
    A fuse is blown on the driver board. You should either test all the drives in I/O mode or swap the driver board (sits above LVPS)
    • Juggy
      Technical Support
      • Sep 2007
      • 101
      The driver board has almost around 12- 13 ICP which is like fuses, you need to check for the one which is open and repair it with a fuse which is less than 600ma in some cases or 1 -2 amps in some cases.
      • ATSBMCO
        Technical
        • Oct 2007
        • 70
        konica 7020
        Thank you,
        You fellas where correct!
        Replaced the faulty ICP and the customer is now back up and running.
        • GottaFixEmAll
          • Jun 2007
          • 55
          That happened to me as well, funny, the problems that never come up in the training school ... Real Life !!!
