bh600 cleaner build-up
  • KM_Service
    • Feb 2011
    • 13
    Replace Clutch.
    If you don't have the part strip an clean the mechanism
    Don't expect the unexpected...............It ruins the surprise !!!!
    • acsolutions
      • Jun 2010
      • 519
      I replaced the whole processing assy. which includes the cleaner, clutch and dev. assy. and it's doing the same thing. They are using generic toner, so i'm going to replace the developer powder and use konica toner and try again! I'll let you know!
      • Downunder
        • Aug 2007
        • 174
        The clutch can be dismantled and cleaned quite well. You will see the gear move as mentioned in your previous post but the clutch part of it may not. They get a bit sticky, or tight. There are some fine washers, might be a plastic transparent, so be vigilant when and if you pull it apart. Done a few now and 80 per cent success.
        • KonMan
          • Mar 2010
          • 15
          #19
          sorry its switch 23 2 and 3.
          • acsolutions
            • Jun 2010
            • 519
            #20
            Ok, I think I resolved the problem!
            Later on I started getting a copy quality problem and checked the toner (contract includes toner in there aggreement) and noticed we had not sent the customer toner in a year, I asked the customer where they were getting there toner? They said they got a kit resantly, the kit included a way to bore a hole in the container and funnel toner in. I did a developer change and installed OEM toner came back on friday for followup, everything looks good. copy quality and cleaning assembly.
