Bizhub error code
  • Chronus102
    • Aug 2025
    Bizhub error code
    i have a C-6102 (i'm pretty sure thats what it was) error code on a minolta bizhub c352, i'm not sure what the code is but i have seen it twice on this machine and just checked the machine for anything and powered it off and then back on and it seems to fix the issue but if it happens again i'd like to know what that code means.
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • masterchill
      • Jul 2005
      • 100
      Check and make sure the scanner cables are sitting ok.Slide the scanner and make sure they do not over lap.Had one do this to me.
      • Chronus102
        thanks for the quick input, right now it seems to be working fine but if it happens again i'll be sure to look at what you all suggested, thanks again
        • cobiray
          Passing Duplication Xpert
          • Mar 2008
          • 1199
          C352 light copies after heavy coverage
          whoops, should've been a new post
          Last edited by cobiray; 08-12-2008, 04:24 PM. Reason: whoops, should've been a new post
