c4707
  • wcody76
    • Jun 2010
    • 20
    c4707
    i have a bizhub 600 thats has lock me out i am unable to get into service mode let alone select anything on the ops panel if this happen to anyone and they have solution please let me know thanks
  • albasoul06
    laser unit
    57AA -650 1
    • tomcatt
      • Jul 2010
      • 92
      Re: c4707
      Am looking for guidance in removing the laser. Guessing from the front after removing control panel???
      • JustManuals
        • Jan 2006
        • 9838
        Re: c4707
        Paul@justmanuals.com
        • Darren King
          copiertech
          • 652
          Re: c4707
          Remove the left cover. You will see a metal cover with a hole and a connector in the hole. remove the connector then remove the metal cover. Unplug the connectors and loosen the screw in the middle bottom the the printhead. Slideout the printhead. To install reverse procedure.
          Be sure to turn off and unplug the machine before starting this procedure.
          Hope this helps.
          Darren
