We are fighting a print shop C5501 that is varying as much as 2 -3 mm side to side (in the main scan direction). Lead to trail registration is fine. There is no skew. We did the centering adjustment for each tray,LU,manual bypass, etc. The tires were replaced for each feed station. The side to side registration will be perfect at the start of a single sided run sent from the network and gradually shift as much as 2 to 3 mm by the time copy number 100 is done. The machine total counter is only 200k.
Any suggestions or help is sure welcome
