konica1015.1216.1120.1212
  • cliffhangers
    • Feb 2010
    • 243
    hello,those konica1015.1216.1120.1212 are given me problems with the by pass tray at times it picks at times it dose not,and i have check every thing and con not fine the fault.if any one has had this problem and solve it let me know so that i can do with mind.I thing the problem is calming from the memory,i need help on this.THANKS IN ADVANCE.
  • Luther
    • May 2006
    • 682
    since these models are about 15yrs old i would replace the feed belt and the double feed tire, the belt is wrapped around a plastic hub and the entire bypass section can be removed, also check to make sure the paper is being lifted to the belt to feed the paper, very simple assembly there isn't much to it really to go wrong, if you need the manual let me know i may still have it
