c-450 error code c2152
  • osman
    • May 2025
    Hi I got my hands on a Minolta C450 device. My issue is I looked at the service manual c2152 error changed the result in the same unit and transfer belt, the black drum gear group (black drive) took down the device I think I did a sync error c2152 error, remained constant. I would be happy if you help people with the technical document I would be glad shares. Thank you very much ..
    Ramiz
    copier technician
  • SKTeK315
    Walter
    • Jun 2009
    • 142
    I'll help you my friend. I had this code today on a c351 which is the same as c450. In Srvc mode in trouble you'll find all codes & what they mean. It's written. The code is, " Transfer belt unit SEPARATION. I turned it off & on. It started working. If not. Trouble clear & cleare code in counters
    • stryker3k
      • Jan 2011
      • 11
      With the belt unit separation error, i have also found that you can simply take the belt out and rotate the gears by hand, apply a little lube and put it back and it will generally last after that.
      • SKTeK315
        Walter
        • Jun 2009
        • 142
        Noted. Tnx.
