C552 Account track blocks prints with "Print Without Authentication" enabled
  • mrwho
    Major Asshole!
    • 4299
    [Misc] C552 Account track blocks prints with "Print Without Authentication" enabled
    I'm pulling my hair out with this one. Here are the details:
    - C552 with account track enabled and accounts created
    - "Print without authentication" is enabled so users don't need to insert user code in driver
    - Prints go through a print server running Server 2008
    - On the server's print driver I turn off "Account Track" and "Auto obtain" on the "Configure" tab
    What happens:
    - No matter what are the permissions I give the driver, the driver automatically turns on "Account Track" and "Auto Obtain" without any intervention
    - People can't print even though "Print Without Authentication" is enabled
    What the hell is wrong? I'm all out of ideas... Any help welcome.
    Cheers!
    Mascan42
    Ibid
  • joneze
    • Aug 2007
    • 128
    Im not sure if this will help much, but i had a problem with a C280 driver that would revert setting back to default no matter what i put in there. I think Auto obtain was one of them that reverted back after being turned off. Anyway like you i was pulling my hair out so in the end i contacted KM and it turned out the driver itself had a problem so they send off the info to germany who then release new driver. Maybe check with infohub for the latest driver fixes.
    • mrwho
      Major Asshole!
      • 4299
      Well, this is the latest driver - maybe I'll advise the customer to try a previous version. Thanks for the tip!
      Mascan42
      Ibid
      • tech51
        • 846
        Try putting localhost as the auto obtain address after setting up the driver. This should stop it acquiring data from the copiers IP address...
        • Stirton.M
          All things Konica Minolta
          • Oct 2009
          • 1804
          I'm not a fan of using server side drivers when account track has been enabled, too often have I encountered issues with server side and bi-directional settings. Might be worth while to setup the drivers locally.
          "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
          ---Groucho Marx
          Please do not PM me for questions related to Konica Minolta hardware.
          I will not answer requests or questions there.
          Please ask in the KM forum for the benefit of others to see the question and give their input.
