codes inspecting last replacement(300k) of Image Transfer Belt Unit &Fusing Unit
  • akbareshghi
    • Sep 2010
    • 261
    [Misc] codes inspecting last replacement(300k) of Image Transfer Belt Unit &Fusing Unit
    what is the codes inspecting last replacement(300k) of Image Transfer Belt Unit &Fusing Unit. my intend to find last counter number that these expensive parts (each 450) was replaced . i want to but one c450 stock machines .
    i need to know about the these parts life currently installed in the stock machine.
    please guide me about instruction or service code
    To clarify, tap the Utility key on the control panel. On the display, touch "consumable life" button.
    thank you for attempt
    Color printing with lowest cost per page is my love.
  • humpty dumpty
    • 29
    if you press utility key and then meter count on screen you will be able to print out a list of meter readings and life counters of each device!!!
