T81 on second fax
  • luis8832
    • Dec 2008
    • 250
    T81 on second fax
    Working on a bizhub c280. Installed a fax kit and tested ok. Installed a second fax and getting T81 error code. I switched the boards and the same result. Followed the install guide. Did i miss any special settings for the second fax? Any info would be great.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    I believe that there is a jumper that needs to be changed and then enter service mode and set the second fax line.
    • albasoul06
      1 - The fax target area is set to 'Japan' ????!!!!!!!
      2 - Dial Tone Detection is set to ON. ?????!!!!!
      W H Y ....?!
      • luis8832
        • Dec 2008
        • 250
        fax target is set to us and i tried turning off dial tone detection same result with the second fax.
        • luis8832
          • Dec 2008
          • 250
          i am now experiencing a new problem, the fax is getting cut off. When sending it it will send like 1 or 2 pages. The line will cut off and wait for a redial. Then it will send the rest. This is a new fax board in the unit. Any suggestions.
          • mo0651
            • 1054
            Is the switch on the board been changed to SW1 or SW2 as in setup instructions? and fax initialization go OK?
            • luis8832
              • Dec 2008
              • 250
              yes it did. both initialized properly. When i try to transmit from the second fax it gives the t82 error. also the switches are in proper position, the first one is switch 1 and second one switch 2.
