Bizhub C280
  • dragonman
    • Aug 2010
    • 24
    [Jamming] Bizhub C280
    Has anyone experienced an unusual amount of jamming on any of the C220/280/360 range?
    I have one that keeps jamming from T1 giving jam codes of 3003 & 1144. in one day i can expect 20-30 jams from t1. The surprising part is that it has only done 3000 copies and is less than 2 months old!! i have checked all the obvious and all seems fine. Anyone got any suggestions?
  • albasoul06
    install firmware version GC7-B4
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      Intermittent jam code 1144when feeding from the first tray.
      Solution
      CAUSE:Failure of 1stPaper Feed assembly.
      SOLUTION:Replace the1stPaper Feed assembly (p/nA0ED R731 00 for bizhub C280/C360 and p/n A0ED R732 00 forbizhub C220 ).
      • B0265
        • Jan 2007
        • 718
        Or version G00-B8:
        17. Countermeasure for J1144/J1044.
        Even if the sensor in front of tim. Roller (PS1) is turned on when the judgment of retrying 1st and bypass paper feed, paper transportation is continued without stopping jam(J1144/J1044). [IQBGB_10000553,PEBJTS10000661,PEBJTS09008645, RIBGB_10000369,IQBGB_10001046,IQBBE_10001513, PEBDFS10000676 etc.]
        * This correction can be made disable with the following Engine FW DipSW.
        (1) Enter the Service Mode then set DipSW No59 to 0x01
        (2) Enter the Service Mode again and press the “Stop” key => “0” key => “Clear” key
        (3) Select Engine FW DipSW button.
        NO.10 : OFF (This correction is effective.) (default)
        NO.10 : ON (This correction is not applied.)
        • huntergazz
          • Feb 2011
          • 23
          Hi,
          I have had 30-40 Machines with this problem!! I take the following measeures and I have only had to replace 2 feed stations
          1 - Strip and clean the clutch, Its usually rusted up (Faulty batch from korea konica used in some machines)
          2 - Cut ALL!! the cable ties from the feed station wiring loom (konica manuafacturing put them on to tight and can shot the cables out)
          3 - UPGRADE FIRMWARE TO LATEST VERSION (B4)
          4 - Check the mylor guide alignment on the tray with the feed station rollers (sometimes need to bend it up slightly)
          5 - If the machine has done 80k or more you may have worn feed tyres so change them
          • Stirton.M
            All things Konica Minolta
            • Oct 2009
            • 1804
            Originally posted by huntergazz
            Hi,
            Firmware is now up to B8 on this series.
            "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
            ---Groucho Marx
            Please do not PM me for questions related to Konica Minolta hardware.
            I will not answer requests or questions there.
            Please ask in the KM forum for the benefit of others to see the question and give their input.
            • minimerlin
              • 851
              The sep roller torque limiter grease goes hard , strip, clean and regrease, also make sure the vertical transport clear plastic guides have not popped out...easy to do if users are careless!
              Please do not PM me without asking first.
              • acusso1234
                Tecnico
                • Dec 2008
                • 250
                "make sure the vertical transport clear plastic guides have not popped out"
                This is the first thing to see.
                ... In the minute that you're thinking of giving up, think about why you lasted so long ...
                • MINOLTAMAN1
                  • Nov 2015
                  • 11
                  Re: Bizhub C280
                  There is a modification that includes little gray tabs that (supposedly) keep users from breaking off the holding tabs on the vertical transport clear plastic guides. These are broken off more often than not. Tabs clip on ears to strengthen.
                    • 14937
                    Re: Bizhub C280
                    Resurrecting a post that is almost five years old. I think that is a new record.
                    • allan
                      RTFM!!
                      • 5462
                      Re: Bizhub C280
                      Jip. Those reinforce parts really works well. Install those and the customer will need to find something else to break.
                      Whatever
