C250 stamps a copy as "copy"
  • Solotime
    • 223
    OK so I have a customer who after having this machine for over a year suddenly wants their copies to have "copy" stamped or printed on them when copied. They say their old copier did it (Ricoh 2027) as well as their other offices have copiers that do it. I have never even heard of such a thing. So my question is will the C250 do this and if so how is it "turned on".
  • racosta
    • 53
    Hello Solotime. To answer your question it will do a watermark on it but it will only do it on print jobs. You have to look in the print driver under edit watermark. Unfortunally it wont do it in copy mode. A suggestion would be for the customer to print out half a ream to a ream of pages with the "Copy" watermark on them and have them put that in a deticated tray so when they make a copy they will have the watermark on it. I hope this helps.
    Rich
    • Hemlock
      • 432
      Just looked at the User Manual for the BizHub6500; Image Overlay is used to put a stamp on every copy (and it does say, specifically, copies). Next, you would likely set Image Overlay to be on as a default setting at power up (not unlike how you can default the machine to double sided, stapled, etc.).
      I'd imagine that a UI feature like that would be universal across KM boxes.
      “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'” (Isaac Asimov)
      • racosta
        • 53
        Hey Hemlock... Unfortunally the C6500 is a completely different beast than the C250.
        • BIG PAPA
          Da Boss
          • 234
          For copying go under your applications and select stamp.
          sigpic
          • Solotime
            • 223
            I have a C250 in the warehouse so I went and checked. Sure enough, under applications there is a copy protect tab which puts a light background over the copy with the word "copy" running up and down the page. So I ran out to the customers office to show them my new found knowledge... Guess what, that function is not on their machine. It only has the time/date stamp, and 2 others I can't remember but no copy stamp. So at this point I am assuming it must in a firmware update? They really did not like the sample I brought them anyway....the grey background it puts over the copy they did not care for much. They really just want the word "copy" printed like in the upper right hand corner.
            • BIG PAPA
              Da Boss
              • 234
              I wouldnt use the copy protect. I would use the stamp function. It doesnt put the background. it just puts the copy stamp.
              sigpic
              • Solotime
                • 223
                Yeah there is no copy stamp option. Just the date/time and 2 others. Same with our machine in the warehouse. No just copy stamp option.
                • BIG PAPA
                  Da Boss
                  • 234
                  I would look into firmware. Just looked at out C250 and it is there. I believe HDD must be enabled, so if it was disabled for some reason? But it is there.
                  sigpic
                  • Hemlock
                    • 432
                    I'm aware of that. Manufacturers also tend to make user interfaces (and common features) standard across the brand for ease of use.
                    • huntergazz
                      • Feb 2011
                      • 23
                      Hi,
                      Im not 100% about the C250, but the newer machines require an extra add on to the machine (SC-507).
                      • oldschool
                        • Mar 2007
                        • 245
                        If copier doesn't have any option for this.. What about a clear piece of Mylar with the word COPY stamped on it attached underneath the glass.
                        Jamex Tech Support: Saving the world one phone call at a time.
                        • tech51
                          • 846
                          Yep had to do this at an American Airforce base (RAF Lakenheath) back in the analogue days only we used enamel paint. If I remember rightly it was a Konica 760 and we had to import a US drive unit for it so it could cope with reducing and enlarging Imperial paper sizes! Happy days eh, no printing, no faxing, no scanning, NO WORRIES!!!!!!
                          • Stirton.M
                            All things Konica Minolta
                            • Oct 2009
                            • 1804
                            I agree, firmware update.
                            "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
                            ---Groucho Marx
                            Please do not PM me for questions related to Konica Minolta hardware.
                            I will not answer requests or questions there.
                            Please ask in the KM forum for the benefit of others to see the question and give their input.
