How can i set Bizhub C252 to print only in BLACK color from touch panel.
  • whiskas_thedogg
    • Jul 2025
    [Misc] How can i set Bizhub C252 to print only in BLACK color from touch panel.
    Hello
    Can any one tell me, how can i set Konica Minolta Bizhub c252 to print only black color from the touch panel.
    The default setting is AutoColor, and i want to set the black color to be default, but i can not find the settings for that.
  • rprem
    • 49
    u can make it to single color mode to take black print outs,setting is in the autocolor mode only
    Head Lines Are Made When Dead Lines Are Met
    • huntergazz
      • Feb 2011
      • 23
      Hi,
      when you click on autocolour it will bring up a manu where you can select black only. After selecting this you press utility counter > user settings > copier settings > default settings > current settings, then ok and exit menus. when you press the reset key it will lock black as default.
      you can also do this for any other settings you need, such as duplex etc
      • whiskas_thedogg
        Thanks man, u made my day. King Regards
        Originally posted by huntergazz
        Hi,
