bizhup 130 f
  • BAAKLINIELIAS
    • Aug 2025
    bizhup 130 f
    bizhup 130 ,black copie go out ,the exposhure lamp is ok some one can help
  • mrwho
    Major Asshole!
    • 4299
    How black are the copies? Are the completely pitch black? Or are you able to read the text you're copying with some heavy background?
    If you print something, how does it come out?
    If you look at the drum, is it covered with toner?
    Try to take out the drum unit and placing it back in - the corona could be badly seated.
    Mascan42
    Ibid
    • BAAKLINIELIAS
      bizhub 130 black copie
      thanks ,the copie is all very dark i can't read anythings ,i will try to do what u say ,because i can hear the strange noise and, maybe it's the high voltage of the corona.
