fax problem on 183f
  • alonzo
    • 63
    fax problem on 183f
    I have a 183 that can recieve but cannot send, I also got a error 0094 machine still operates need help.
  • mo0651
    • 1054
    check your market area. should be set to us. power glitch changed one on us.
    • alonzo
      • 63
      183f not recieving
      checked on setting set on usa still will not recieve hooked up another fax everything workingon replacement fax, what do you think fax board or something else I can try first.
      • alonzo
        • 63
        183f fax problem I wrote it would not recieve I ment it wont send.
        • stevelau
          • Jul 2010
          • 21
          Either is the setting problem or try changing a fax card(NIC card)
