quality problem
  • jokacross
    • 110
    quality problem
    I have a problem in color copies. By taking several at once the first leaves and then the sound quality will be lost as it exits. What can do this? I can send a picture of this if you want thanks. Is a 450c
  • BIG PAPA
    Da Boss
    • 234
    I would say that yes a picture is needed. Not sure what sound copies make and why it would be an issue. But a few more details and can probably give you some advise.
    sigpic
    • jokacross
      • 110
      The 1st page is the 1st print and the 2second page is the print past 16th prints. If you don't understand tell please
      prblem c450.pdf
      • BIG PAPA
        Da Boss
        • 234
        When is the last time adjustments were ran? If you are unsure do a reset and stabilize then run gradation adjustment as per manual.(at least 3X per setting).
        sigpic
        • jokacross
          • 110
          can you explain me all the steps to do that? You have a pdf explaining that? thanks a lot
          • stevelau
            • Jul 2010
            • 21
            believe you need to redo the gamma & gradation adjmt. It will improves the print. Suggest you to do the toners replenishment(CMYK) before doing all this adjustment.
            • jokacross
              • 110
              every thing is all right now. Thanks a lot for all your replys very very much!. My machine right now is very good quality.
