Bizhub C5500 - bypass Tray does not autodetect Legal Size
There is no Bypass Paper Tray adjustment for paper size detection.
If the tray is not recognizing paper sizes correctly:
1.Ensure that the three holes in the Side Guide Pinion (gear) aligned properly. Two of the holes align with holes in the Side Guide Racks and the other aligns with a hole in the Mount Plate for the Side Guide Pinion (# 65AA42620).
2. If the tray alignment is correct replace Size Detection VR (VR4) (# 56AA85601).
3. If problem persists, replace the entire Bypass Unit (# A03UR75000).
