press c6000 config question
+ More Options
Posts
  • lucky13
    • May 2008
    • 125
    going out to do a c6000 install tomarrow sales has ordered c6000,RU506,GBC punch unit,RU509,PB503 and a FS531 . all is good but i cry foul at the fs531 as the terminating option i think they need the FS521 ,i see no config docs or install manual that shows FS531 after the PB503 . i only see a FS531 in an entry level config with main body only or with an RU unit. am i wrong on this ?
  • bizhub1
    • Sep 2008
    • 230
    I believe you are correct, I do not think you can put a 531 after a pb503.
    • RRodgers
      • Jun 2009
      • 1947
      Wouldn't be the first time (or last) sales has screwed up like that, and you'll be left holding the bag. Better tell your boss soon!
      • Stirton.M
        All things Konica Minolta
        • Oct 2009
        • 1804
        See attached expectation setting document for specifics, but you are right. The FS-531 is a basic finisher meant to terminate either directly to the main body (as per page 29) or through the relay unit attached to the main body, (as per page 28).
        Give your sales rep a slap in the back of the head for NOT paying attention to the expectation setting document.
        bizhubPRESSC7000_C6000_ExpSetDoc021711.pdf
        "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
        ---Groucho Marx
        Please do not PM me for questions related to Konica Minolta hardware.
        I will not answer requests or questions there.
        Please ask in the KM forum for the benefit of others to see the question and give their input.
        • lucky13
          • May 2008
          • 125
          thanks that doc says it all , looks like the customer is also short 2 more wall outlets as well
