Konica 8031
  • Bryan B
    Konica 8031
    Does anyone know how you can get this machine to do a full bleed?
  • dogsbody
    • Jun 2007
    • 289
    Never had a customer want to do it but on training was told you have to use an oversized paper and trim the edges.
    The force will be with you always.
    • random
      Well the max size for this machine is 12"x18" or 304x457. Depending where you are in the world you either want the size to trim to a3 297x420 or ledger 11x17. So you need 12x18 paper or paper 304x457. Then keep you print size to a3 or ledger and the trim down. The machine will not print edge to edge.
      Put your oversize in tray one and with some luck it will automatically pick up the size, otherwise you will have to set the size manually.
      Good luck!
      • Bryan B
        Thanks. that is consistent with what I have found in research. Unfortunately I was sold the lease on the idea it was edge to edge bleed with not trimming involved.
        You guys are great!
        Bryan
        • random
          No problem, FYI you will not find a toner based photocopier that will print edge to edge.
