First Network Fax BH250
  • JR2ALTA
    • Feb 2010
    • 2033
    Installed Network Fax from CD. It loaded a GUI called "Network Fax for Windows", and a CUIPS port.
    I entered the copier's IP address in setting called "Fax IP Address" within the GUI.
    I don't get any errors, but every fax I send out just prints at the machine and never gets transmitted.
    Thanks in advance.
  • Hansoon
    • Sep 2007
    • 3389
    Which operating system?
    Hans
    • mo0651
      • 1054
      I am pretty sure that it just doesn't work. Look for a tech bulletin. Even the BH222 Still did not network fax. We had this issue. And got it replaced by KonMin after haggling.
      • aesthetics1
        • May 2010
        • 148
        There is an article in the knowledge base about this. There are two possibly solutions. Enabling Gateway TX I believe, and updating firmware to the most recent levels. (make sure you use the correct phase version, as there are two based on the serial numbers of those machines, I believe, all from memory, sorry.)
        • aleksander
          • 378
          Thanks in advance.
          Go to your MFP, Press utility/Counter - Admin Management - Enter password - Admin 2 - Network Setting - Basic Setting - Scanner Setting. Change the Gateway TX to Allow.
          Try it.
