Please hellp me C350
  • shady1988
    • Jun 2007
    • 30
    Hello dear all !
    I have this problem with Konica Minolta C350:
    - I have change the IUs 4 colors and after 10000 prints I have see a scratches on the PC drum of the yellow unit too much like this pic DSC0070333.jpg ,Cyan unit a little bit and magenta else black unit.
    *By the way I see there is a toner fallen down from wast toner exit of the IUs.
    - and I late the time for changing the ozone filter and paper dust remover because I don't have them now and I use compatible toner from KATUN co ,So is those can make this problem.
    Please help dear all and many thanks ...best regards
  • shady1988
    • Jun 2007
    • 30
    Please guise !!
    Help me I'm really hot to fix this problem
    • acusso1234
      Tecnico
      • Dec 2008
      • 250
      My customers all use original toner. Maybe this is the reason why I never seen this. The other thing i'd like to say you is to check the point of tranfer belt that meet the waste toner bottle. Maibe it is not open or broken.
      ... In the minute that you're thinking of giving up, think about why you lasted so long ...
      • CT Copier Repair
        • Mar 2010
        • 304
        oem Toner
        always OEM toner on production color machines
        and the waste toner system needs to be cleaned and filters changed ASAP
        • stevelau
          • Jul 2010
          • 21
          If there is toners spilling, most likely the toners is not compatible. Try service/clean up the C350. If the drum already scratch, then you can't do much but to change a new set in and put in new CMYK toner(original) and see whether this happen.
          • karim-tech
            • 47
            try to use an origibal toner for that u can use the toner of C6500 or C5501 with a nice price
            also u have to do an graddation adjust befors u have to initialise the graddation
            call the service mode and imagnig process adjust go to stabilizer and then start
            before u change the toner try to lose all the rest of the bad toner by copying more of color
            • empiru
              • Feb 2011
              • 229
              I've seen IUs like this many times. The reason - most likely the comatible toner from KATUN. All our clients use this type of toner, obviously because it is cheaper. So, what we do is, we clean the drums with a cloth full of alcohol (I'm sorry, I don't know the exact term - it's a solution that contains 99,6% pure alcohol).
              Of course, after another... let's say 10.000 prints, the drum will look the same as it looks now. So, if you want to repair this problem once and for all, I too suggest that you change the toner and use OEM from now on.
              Good Luck!
              I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
              • Hemlock
                • 432
                If the customer is buying the Katun toner, bill them. They'll learn quick.
                If the boss is buying Katun toner and shipping to customers, enjoy the job security.
                “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'” (Isaac Asimov)
