C-2863 - Konica Minolta BizHub 6501
  • poujman
    • Jul 2025
    [Error Code] C-2863 - Konica Minolta BizHub 6501
    Hi Everyone
    i hope someone can help me with this issue. at end of Friday, where i need the machine the most, our printer decided to fail on us with error code C2863. I am hoping someone can help us to ge the machine going with out PM before monday. All helps are highly appreciated.
    Thank you in advanced for your help
  • acusso1234
    Tecnico
    • Dec 2008
    • 250
    C-2863 Gamma correction/C aborted.
    Patch output voltage is high.
    (Error 3)
    Printer control board (PRCB)
    Developing unit/C
    PGC sensor (PS11)
    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
    • acusso1234
      Tecnico
      • Dec 2008
      • 250
      The "strange thing" that you see in my Pdf, is located on the left of the transfer belt. If you can take out the entire section whith drums, transfer belt and developers you can see and clean it. Do not force nothing and only try to clean the sensors whith canned air if you have it.
      • poujman
        since i never done this before are you able to give me a better step by step instruction? because looking at the pdf it was bit confusing. i am able to open the front door, remove the screw see the drums and developer units but i am not able to discover the sensors. can you give me like picture of what i am suppose to clean up? thanks for your help
        • acusso1234
          Tecnico
          • Dec 2008
          • 250
          As i said before you must take out the entire group. Than put your head into the machine and look at left whith the help of a flash light.
          Probably you'll see lot of toner on this part. you can open it (gently) a little and use air to clean sensors.
          • CT Copier Repair
            • Mar 2010
            • 304
            call a technician
            if you screw up the sensor or a drum you will cost yourself more money than it would have cost you to call a technician
            It blows my mind that people think they can fix these themselves
            i've been at it for 26 years and still see stuff i never saw before
            • acusso1234
              Tecnico
              • Dec 2008
              • 250
              Sorry but I believe that I've posted already the best image of the entire manual. no picture avalaible of this "shutter dispositive". Then? have you take out the slit whith the drums?
              • acusso1234
                Tecnico
                • Dec 2008
                • 250
                Originally posted by ct copier repair
                call a technician
                We have a C6500 in the office. The salesman was able to do this.
                • acusso1234
                  Tecnico
                  • Dec 2008
                  • 250
                  Sorry for my bad english...I've write "on the left"...But it is AT the left of the tranfer belt (when the unit is still into the machine). when the unit is out the sensor stay always into the machine. Hope that this help you to find it.
                  • acusso1234
                    Tecnico
                    • Dec 2008
                    • 250
                    News???
                    • poujman
                      News???
                      yes thanks you so much! what i basically did. i pulled it all out and then i just blow dry it everything that looked like sensors on the side without touching the transfer belt and then closed it and turned it up and it was back up again. thank you so much for the help i really appreciate it.
                      • acusso1234
                        Tecnico
                        • Dec 2008
                        • 250
                        In Italy we say "prego s'immagini!".
                        • poujman
                          perfecto!
                          • rnicholson
                            I am having the same issue
                            Didi you have to take the entire image correction unit out to clean the senso?
                            • ni311
                              • May 2008
                              • 658
                              The best bet is to call a tech. I cannot believe you people without any training are servicing a complex machine like C6500. Sooner or later you will have to call a tech and it might be a little expensive...
                              Konica Minolta Error Codes - Explanations and Solutions
