code c2557 in c550!!!
  • gang1110
    • May 2010
    • 43
    i got error code in c550 c2557 problem with the tcr value in black image . i check the tcr
    value its standing on 4.5% and after copule of paper there is error code . i try to supply
    toner to the image and after that the tcr shows 7% its good but again after we print
    the error code show again c2557 and the tcr show 4.5% . the iu black new and i try to
    replace nothing change maybe there is problem with the hooper maybe its fake or problem
    with the motor of toner supply?
  • ddude
    General Troublemaker
    • 473
    There is a problem with the IU working it's way loose, which can cause loss of bias and CQ problems, maybe causing toner errors- Check you image unit for any damage to the drum?
    2000 mockingbirds = 2 kilomockingbirds
    • gang1110
      • May 2010
      • 43
      i check with another unit is the same problem
      • CraigW
        • Dec 2010
        • 417
        Is the K image unit holding plate mod being used on this machine ??
        • Zeldaman
          • Mar 2011
          • 946
          Hi there!
          Had the same problem some month ago, the problem was not enough tonersupply caused by a bad sealing of the tonercartridge. Installed anew one-OK.
          Greetings..
          • gang1110
            • May 2010
            • 43
            the problem was found i replace the hopper of the black iu thank for everybody
