Konica 7085 not centering
  • otomatic
    • Jun 2009
    • 26
    Hello all
    we have a 7085 that the image will not center
    the printer centering adjustment in 36 mode does nothing
    test print 16 is to the left of center 3mm
    we adjusted the trays to get it that close to center and for most things this works fine
    there is no codes
    and have checked all the sw switches
    sensors are clean w/good connections
    what's next
  • albasoul06
    SW 12-3 set to 0
    • jma676
      Expert Tech
      • Mar 2009
      • 324
      Re: Konica 7085 not centering
      Something similar happens in my field with a Konica 7085 - IP602, the case is ..
      that the automatic centering works well on 36 mode, with 12-3: 0 ofcourse,
      but then when printing.. centering problem remains.
      Any problems with the IP602?.
      Then I'll make the adjustment manually.(12-3: 1)
      • BIG PAPA
        Da Boss
        • 234
        Turn the switch off, then make your adjustments, then turn it back on. Otherwise you are just fighting against the auto adjust.
        sigpic
        • otomatic
          • Jun 2009
          • 26
          no problems with the IP602 that I'm aware of
          this machine simply won't center no matter what 12-3 is set to
          I've done these adjustments on our other 85 and it works perfectly
          I do have a parts machine that I could swap parts out of but not sure which parts are involved with the auto centering
          • jma676
            Expert Tech
            • Mar 2009
            • 324
            ofcourse, as I said in my previous post.
