Bizhub 1050p tray#4 pf701
  • pudgi300
    • Sep 2007
    • 193
    Hi
    I am having a problem with Tray #4 jams in the drum area. Reg is fine. The paper goes up in the drum area between the drum and developer. The paper i take out the registration is perfect. It is like a seperation problem. Replaced all rollers and clutches in tray 4.. Also 2 clutches in rear of pf701 for tray 4. I even swapped tray #5 with Tray#4 and that one will cause jams in the drum area with tray 4 selected. Does not matter what paper i use but 20lb 8 1/2x11 works better. I am logging 31-02 and 14-01's. I can run out of any other tray with no problem. Has anyone ever seen this one before.
    Later Pudgi300
  • pudgi300
    • Sep 2007
    • 193
    Machine is now working fine out of tray #4
    Went in tonight and watched copies passing over transfer out of tray #4 and they were going high toward drum. Ran same job and paper from tray #5 and no problem. Checked tray paper weight for tray #4 and it was set at 162-209g. Set it back to normal and ran 500 nice and flat accross the transfer. I would swear it said normal before. Live and learn. Been doing copiers for 34 years.
    Got my pf701 nice & clean now and 2 new tray 4 clutches.
    Later Pudgi300
    • watson
      • Sep 2009
      • 64
      Some different colored papers have separation problems also in the 1050. Something to keep an eye out for.
