BizHub Pro 1050 EP - Maintenance interval v's Actual replacement interval
  • scotsman60
    • Mar 2011
    • 32
    The Field service manual for the BizHub Pro 1050 EP identifies various maintenance intervals - 750k impressions, 1.4 million impressions etc.
    But in the maintenance tables it also references "Actual replacement cycles".
    For example the Paper Feed Roller in in the Pick Up Section is referenced in the 2.25 million cycle maintenance interval but has a not saying that the actual replacement cycle is 500,000.
    How should I interpret this?
    I'm trying to make sure I have an inventory of parts on hand for maintenance/repair without keeping absolutely everything in stock.....
    Thanx!!!!
    Doug
  • Hemlock
    • 432
    I'd read that as 500,000 paper feed actions or 2.5 million clicks on the machine, whatever comes first. Probably based on the assumption that rubber is gonna dry rot over time.
    “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'” (Isaac Asimov)
    • scotsman60
      • Mar 2011
      • 32
      That makes sense - I can apply the same logic to several of the other items.
      Thanx!!!!
      Doug
