Konica C6500 weird black strip.
  • condor99
    • Sep 2009
    • 23
    Hi
    On both my Konica C6500's I am getting a weird stripe on the right side of the paper, shows up on the black only. Since its happening on both, I am thinking it is NOT a mechanical issue, and maybe a setting problem in service mode. Any ideas?
    Image is attached
    FYI, I changed the developer unit, coronas, did 200k PM kit... any help would be great, a very annoying problem.
  • Christian_W
    Support Specialist
    • Jan 2011
    • 33
    Hi Condor99,
    have you this problem with all kinds of paper?
    In my mind, there was a setting for a black problem with thick paper. Think it was a DipSW.
    Christian
    • condor99
      • Sep 2009
      • 23
      Hi
      I think on thinner stock it does not occur, but I already turned on the thick paper mode. I also put the 2nd transfer roller to low.
      • pinoyprinter
        • Mar 2011
        • 17
        hi
        please check the laser path of write unit in black.
        • Desert Rat
          • May 2008
          • 1089
          Looks like a shadow, does this happen with the doc feeder? or with 11X17" paper? Was this a copy or a print? Does this
          happen with the machine generated test targets?
          I would agree with pinoyprinter and eliminate the laser path. It is common to both modes.
          Do you have all the pubs for this model?
          DR
