C280 intermittently locking up
  • progoffice
    • Nov 2008
    • 337
    I've got a C280 that intermittently locks up. I'm still trying to establish some sort of pattern to this. When it locks up, the panel stays on but is not responsive to touch. You can even turn off the sub power switch and the touch panel stays on. The network status lights on the NIC show activity, but I am unable to ping the copier once it freezes. Firmware is up to date. There is usually a print job in queue when it freezes, but after resetting the machine, the backed up print jobs proceed to come out without issue. I'm leaning towards the main board or possibly the hard drive. Account Track is turned on. Anybody else experience this issue before?
  • acusso1234
    Tecnico
    • Dec 2008
    • 250
    Not on this model, but in the past a logical format of the HD worked for me. If you decide to try it print your list of settings .
    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
    • progoffice
      • Nov 2008
      • 337
      I've thought about doing that, but would a hard drive issue cause the machine to not ping successfully?
      • Zeldaman
        • Mar 2011
        • 946
        Hi there!
        Had a similar problem, pull out the RAM-chip, cleaned the contacts, then it was OK.
        Greetings...
        • SmellsHot
          Head Tech
          • 512
          I had the same exact problem, ended up replacing main board and NVRAM to fix machine. I would try reseating connectors first though.
          Everyone has the right to be stupid. Some people just abuse this privelage more than others
          • progoffice
            • Nov 2008
            • 337
            Don't you just have to transfer the NVRAM from the old board to the new board. I've had to that several times on the C253/353's when replacing the main boards. I've already reseated connectors. Would a line conditioner help in any way to alleviate these things from happening?
            • jonw
              • 57
              Have you tried reinstalling Firmware. I had a very similar problem same M/C
              • progoffice
                • Nov 2008
                • 337
                Twice
                • Tom40
                  Change the RAM
                  • pinoyprinter
                    • Mar 2011
                    • 17
                    i experienced this before..
                    back up your account track, turn off the HDD then try printing.
                    if still occurs try first firmware upgrade, if not, replace nvram/memory.
                    • emujo
                      • Jun 2009
                      • 3009
                      Ditto on the RAM, had the exact same symptoms on a C550 recently. Much cheaper than a SYS bd. EMujo
                      • progoffice
                        • Nov 2008
                        • 337
                        I think I'm going to try the RAM on this one first. Who do you guys order your RAM from for these color machines? In the past we've used Techworks for Kyocera machines.
                        • emujo
                          • Jun 2009
                          • 3009
                          I'm a KM dealer, but our part # is V865 3000 26. Emujo
                          • DCPS
                            • Mar 2008
                            • 116
                            Try to deactivate SNMP on the machine and on the driver too.
                            • progoffice
                              • Nov 2008
                              • 337
                              I installed a line conditioner (couldn't hurt) and based on the advice here, some new RAM. Customer reported back that it froze up on them again. According to them, there were no jobs in the print queue and it was not in use when someone realized that it had froze again.
