konica 7022 + df314
  • LY3IJ
    • Sep 2007
    • 53
    [Jamming] konica 7022 + df314
    df314 scans 1 side ok then stops(does not try to pick paper back) showing j62-3 code
    what could i do with it?
  • BIG PAPA
    Da Boss
    • 234
    Are you trying to do two sided? If memory is correct it is the same motor, it just goes in reverse. Is it spinning? Either that or a clutch.
    sigpic
    • mrwho
      Major Asshole!
      • 4303
      If the paper doesn't try to move back, I'd bet on a sensor that doesn't detect the paper arriving at the end.
      Mascan42
      Ibid
      • LY3IJ
        • Sep 2007
        • 53
        thanx will check motor cluch & sensor at the nex visit
