Bizhub c450
  • thuo
    • 155
    Bizhub c450
    Hi
    i have a bizhub c450 with embedded controller but cannot print thru network.
    i suspect i am making the wrong selection of the controller. there are 4 controllers options .which controller should i use and which mode (mode 1, 2,3)
    thanks
  • mrwho
    Major Asshole!
    • 4299
    Controler 0 - The mode, afaik, is irrelevant.
    As for being unable to print, if you can't get around it (does it ping? can you access it via web browser?) then you might need to reset the nic via a special firmware card.
    Mascan42
    Ibid
    • empiru
      • Feb 2011
      • 229
      Can you print a test from the copier controller menu? If yes, than it is not a matter of setting the Controller, but a matter of the driver you use.
      I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
      • niodar
        Hi,
        try go to service mode-system input-peripheral setting..
        choose the controller no 3...
