Please Help ICD 17
  • unvisible
    • 10
    Please Help ICD 17
    hi to all.
    Please take a pic from REYB/PH ICP6 and PRCB ICP17 and Printer Control Board (PRCB).
    My machine have a error c_4501 and i search in net and etc. but not find propert answer. i change ph unit but now i have this error.
    thanks
  • unvisible
    • 10
    i finde icp 6 on ph unit bord how i can test it
    • unvisible
      • 10
      No body can help me to solve this problem (c-4501)???????
      • Brischaffer
        • Oct 2008
        • 68
        What kind of machine are you working on???
        • emujo
          • Jun 2009
          • 3009
          ICPs are small resistors that protect the PWB from overcurrent if the load associated with it has an issue. You can check them by "OHMing". Just like a fuse. Problem is if they are open you have to replace the board anyway. If you have a blown ICP you should replace the componant it protects at the same time, if not, you will probably blow the ICP again. On the C650 series this indicates a problem with the REYB/PH. On the production print MFPs it also indicated a PH problem. Emujo
