C253 background_help please
  • jrf
    • 142
    C253_Scan.pdfThis C253 started banding and then produced complete background, I have attached a sample. I have changed image units, black print unit, hv board and PWB assembly but still no luck. I would appreciate any help.
    Thank you
  • fishleg
    • Mar 2009
    • 426
    Curious that a test print out the machine or copy ?
    • jrf
      • 142
      This is a test print fishleg
      • jonw
        • 57
        what happens when you do a gradation adlustment ?
        • acusso1234
          Tecnico
          • Dec 2008
          • 250
          Did you tried a inizialization and a complete calibration?
          ... In the minute that you're thinking of giving up, think about why you lasted so long ...
          • jrf
            • 142
            can not complete gradiation because it gives a test pattern scanning error
            • Zeldaman
              • Mar 2011
              • 946
              Hi there!
              I think acusso is right. Your sample looks like the older color-bizhubs when there was made a mistake in the installation-procedure.
              try to make a complete set-up all after the installationmanual.
              Greetings....
              • Mercutio Norway
                • 11
                I've seen this before, experienced it on a Bizhub C353.
                Try change the Printer Control Board. If my memory isn't playing me a trick I had some success with that one.
                Best of luck!
                After careful re-thinking... My memory was playing a trick on me.
                Soz!
                • jrf
                  • 142
                  Ya waiting on boards now, ill let you know the solution as soon as i sort it.
                  Thanks for help
                  • jrf
                    • 142
                    Just to update you on this one, The MFPB board was the cause of problem,
                    Thanks for all your help
