I can print single-sided copies just fine, however, when I try and print double-sided documents, the Bizhub C351 will print the first side, but when it tries to pull the paper back through to print the 2nd side, it stops. I can hear the gears are TRYING to turn, but are making a grinding noise when they try and pull the paper back through the machine to print the 2nd side. Any suggestions?
Bizhub C351 Duplex Printing stops
