bizhub c220
  • solomon
    • Aug 2025
    bizhub c220
    help this machine white sports on printout on 300grams grocey paper,on other papers it is oky.any one
  • ineo+6501
    • Mar 2010
    • 262
    That's an easy one. The C220 is only rated upto 271gsm. 300 gsm is beyond the machines abilities.
    • boanda
      • Feb 2011
      • 79
      But it can print on 300gsm and it has fine copy. U need to abrade the sheet metal where the contact on door of second transfer roller touching the machine. (I hope u understand my bad english)
      That is official factory problem!
      • aleksander
        • 378
        You can read the official brochure bizhub C360/C280/C220. ineo+6501 told you the right things.
        • aleksander
          • 378
          or you can read the service manual for detail.
          • lucky13
            • May 2008
            • 125
            grocey paper really ? brown paper bag /construction paper .
            • pinoyprinter
              • Mar 2011
              • 17
              dont print beyond limit of machine specified paper thickness coz it can damage ur Tranfer belt
              • CT Copier Repair
                • Mar 2010
                • 304
                print within specs
                or it prints what it prints
                tell the customer and show them the documentation
                or if a salesguy told them it would get his worthless ass in to explain that he lied to the customer
                • DadO
                  • Dec 2007
                  • 404
                  Re: bizhub c220
                  grocey paper......my costumers push poor c220 to the limit but not whit as lucky 13 stated "brown paper bag /construction paper". LOL... Its fine to print on offset 300 glosy and 250 matt but that "cardbox" of paper is way beyond c220 capabilities .
                  • habik
                    • 2013
                    Re: bizhub c220
                    White spots appear mainly when fuser speed is not adequate to the temperature. I had this when client was printing on 120gsm and settings were Thick 2,3,4 and should be Thick 1. It was on the edge but still the correct settings were necessarily.
                    With 300 gsm it would fairly difficult to judge the correct speed/temperature I think.
                    My personal opinion on this is: Get a better machine or lighter paper.
                    Damage to transfer belt ..? should not occur as there is a room for 300gsm thickness. but bear in mind that 2nd transfer voltage might need to be adjusted too.
                    good luck
                    Firmwares HERE
                    • ExXeroid
                      • Jul 2010
                      • 56
                      Re: bizhub c220
                      ineo+6501 is correct Sir
                      Any adjustments or mods you make to accommodate out of spec paper will just mess up everything else.
                      You are going to bring a whole lot of pain down on yourself, you have been warned!
                      • SCHWARZ
                        • Jun 2011
                        • 47
                        Re: bizhub c220
                        try setting the Transfer Output Fine Adjustment from Service Mode-Imaging Process Adjustment-Transfer Output Fine
                        Adjustment-Primary transfer adjusment. Change the setting value using the [+] / [-] keys. Increase the setting value white spots will decrease.
