konica 7155/7165 problem
  • djsayan
    • Jun 2010
    • 44
    hello
    konica 7155 machine has a problem we turn on the machine he asked Apelles sav SC36-02
    7165 for the second machine it calls the code initializes the counter how the code or the Supreme
  • djsayan
    • Jun 2010
    • 44
    • djsayan
      • Jun 2010
      • 44
      I have a machine konica 7165 it requires a code for the meter voltage
      • ineo+6501
        • Mar 2010
        • 262
        I think you need to use a better translator. We would help you if we knew what you were talking about.
        • djsayan
          • Jun 2010
          • 44
          I have a machine konica 7165 when I turn on the machine it asks me a code for the voltage meter, I do not known how this code then this code Supreme
          • ineo+6501
            • Mar 2010
            • 262
            I am guessing that you have just bought a 7165, and when you turn it on it asks for a password to allow you to use it?
            If this is the case, it sounds like account track is turned on?
            • djsayan
              • Jun 2010
              • 44
              yes
              • djsayan
                • Jun 2010
                • 44
                up up up upu upu up
                • RRodgers
                  • Jun 2009
                  • 1947
                  Originally posted by djsayan
                  hello
                  Goto kmbs.konicaminolta.com and grab the user manual for you machine, it's in there how to setup (or turn off) ECM.
                  • djsayan
                    • Jun 2010
                    • 44
                    I already have the manual machine, but nothing I found how to reset the code counter to walk to the machine
                    • Morlock49
                      • Mar 2009
                      • 166
                      down load the user manual and then goto section and pages 14-18 to 14-25. These pages describe how to make adjustments to account track. it is called ECM in the manual. try all zeros for the passwords. (default).
                      Sorry folks, reputation removed by Just Manuals, because he's a sad little wanker
                      • djsayan
                        • Jun 2010
                        • 44
                        Can you give me the manual. mine it has ONLY 13-60 page til I not find page 14-18 14-25
                        • jobert
                          • Jan 2011
                          • 49
                          Follow this steps first or you may explore the ECM Setting menu.
                          Here's how....
                          1. Off the machine.
                          2. Press Help while you on the machine.
                          3. Input your 4-digit Key-Op password and press OK.
                          4. Press ECM
                          5. Input your 8-digit Master Key Code (try eight 0's or 12345678) and press OK.
                          6. Dissable ECM (Electronic Copy Monitor) by hitting off.
                          • djsayan
                            • Jun 2010
                            • 44
                            Here's how....
                            1. Off the machine.
                            4. Press ECM
                            thank you for your help but I do not have the code for this step''3. Enter your password 4 digit key-Op and press OK.''
                            • jobert
                              • Jan 2011
                              • 49
                              Try four 0's or 1234...
