C550 bypass tray
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    C550 bypass tray
    The copier display says section indicated is open and asks to close section properly. Display indicates bypass section is closed but bypass tray is displayed as down. Very strange. I opened the bypass door assy and the display shows that the whole assembly / door is open. When I actuate the sensor it shows tht the bypass door is now closed but displays that the tray is down and asks to close properly. Any help much appreciated. Unit was fine prior to delivery.
