pro 1050
  • muhammad.imran
    • Jul 2008
    • 13
    pro 1050
    hi
    when i run drum potentail sensor adjustmet error2 appear
    i replaced drum potentail sensor assebly but same
    any body has face this problen or can help me out .
    thank you
  • CT Copier Repair
    • Mar 2010
    • 304
    Drum good?
    • costel fasola
      • Jun 2010
      • 69
      Re: pro 1050
      is too much toner in developer . wrong setting
      • methogod
        • Dec 2008
        • 917
        Re: pro 1050
        i would change DV
        also make sure drum potential sensor is connected well, can be loose bad wire...
        you can usually get away with that error for a while, especially on a high production machine, if they are not huge on quality, and grey scale photos.
        I have seen the DV unit cover not click on all the way so it just pumps toner dust into the process unit in about 30 seconds...
        check your DV age, may be time to change developer. See if you can get a potential reading in I/o or the other way... this way you know if its the drum or sensor.
        what brand of DRUM are you using? OEM or aftermarket?
