FirmWare C252
  • thiagorios
    • Jun 2025
    FirmWare C252
    Hello,
    I need the firmware KM C252 to reinstall my printer.
    so my C252 is showing the hourglass: initialization and saw here in the forum it is necessary to reinstall the firmware. you guys could help me?
    could someone send me by email?
    thanks,
  • JustManuals
    • Jan 2006
    • 9838
    1st post and he wants something. How surprising!
    • CT Copier Repair
      • Mar 2010
      • 304
      I have the firmware
      trade you for 6 numbers that win mega millions
      • thiagorios
        Thanks for you help! not want to help not hinder
        • thiagorios
          I am simply in need of a help, not because it is my first post I should not ask for help.
          • JustManuals
            • Jan 2006
            • 9838
            If you read and follow the rules you'd know that asking for someone to send you something on your first post is not allowed and is frowned upon.
            • RRodgers
              • Jun 2009
              • 1947
              I wouldn't frown apon it if he gave me $1000.
              So yes, ill give you the firmware. Course only after the check clears.
              • thiagorios
                Can anyone help?
                • JSC
                  Gimp
                  • Dec 2006
                  • 618
                  Hello,
                  thanks,
                  You probably need a NV Ram clear/reset.
                  It will save you time and money in the long run if you called out a tech.
                  The gene pool could use a little chlorine.
                  • thiagorios
                    unfortunately the coach of KM here in my city do not know to solve the problem.
                    • JSC
                      Gimp
                      • Dec 2006
                      • 618
                      The thing is what will you do with the firmware if you get it! Do you have the correct type of CF card? Do you have the software to write the firmware to the card?
                      There must be a company in Brazil that can help......
