KMBH Pro C6500 firmware miss match with accessories and fiery ?
  • Desert Rat
    • May 2008
    • 1089
    This install is turning into a marathon call.
    I downloaded firmware for the fiery to the fiery, connected it to the
    machine and it made a nice PS test page.
    The fiery I have is the S450-04 model that sits on the floor. It sez "fiery"
    on the front panel. It is white with black trim and has a door that covers
    the pwr sw and CD drive.
    Is this the IC305? I am not sure of what I have.
    I hooked up the SD501 to the RU504 and then connected the
    FS503 to the SD501. Nothing past the RU shows up on the
    control panel.
    The serial numbers have been inputted and the dip switches are in the
    correct position.
    I've been told I need the ISW tool to download firmware to the equipment
    so all the firmwares in the accessories are compatible.
    I also been told to just go direct to the machine with the thumb drive.
    and I've heard the fiery is the problem
    What am I missing?
    DR
  • bizhub1
    • Sep 2008
    • 230
    Were these accessories previously installed on this 6500? Because they can go on the black and white high end models also, and their are jumpers that have to be changed. I have heard of the jumpers being in the wrong place and the output options not appearing on the panel. Don't think it has anything to do with the fiery. Also heard of people mixing up connectors on the relay unit and blowing numerous boards out. Their is a couple of plugs that sit close together and can get mixed up.
    • Desert Rat
      • May 2008
      • 1089
      This unit came from a wholesaler. So it would be hard to say what these units were connected
      to before this customer purchased them.
      So far I don't believe I have crossed any connectors and the jumper plugs are not installed.
      All the dip switches were in the C6500 configuration.
      DR
      • bizhub1
        • Sep 2008
        • 230
        You should be able to just use a thumb drive for the firmware, i believe its version 60 on that model.
        • empiru
          • Feb 2011
          • 229
          We had the same problem with a Bizhub Pro C6500P, that had a PF601, FS503 (or 501) and a Relay Unit + Creo IC408. It worked fine; one day, we wanted to test a Fiery IC408 on the machine and guess what: The fiery didn't recognyze any Optionals (nor FS, PF or RU). I think it's possible that some Controllers don't recognyze some of the machine optionals.
          I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
          • Desert Rat
            • May 2008
            • 1089
            empiru,
            What fiery is the S450-04? And did that other IC408 keep the options from showing up on the
            control panel?
            DR
            • Desert Rat
              • May 2008
              • 1089
              bizhub1,
              Do you have instructions for downloading from the thumb drive or is there something in
              the manual?
              • seniortech
                • Dec 2007
                • 180
                Updating the Firmware is shown in the service manual...
                • Desert Rat
                  • May 2008
                  • 1089
                  Ok, I'll give it a shot and see what happens.
                  DR
                  • empiru
                    • Feb 2011
                    • 229
                    DR,
                    I have no idea what kind of Fiery that is. My problem was, the optionals were appearing on the screen, but I just couldn't print - because the Fiery wasn't recognyzing the optionals.
                    Now I understand that your optionals don't appear on the screen... that's a tough one... I would try to change the firmware... see what happens - you can't do any harm
                    • Desert Rat
                      • May 2008
                      • 1089
                      empiru,
                      What are the steps involved? I have the firmware and a thumb drive. I can open all the zip files
                      on the drive. Do I just plug it in and turn on the machine?
                      Have done this from just a thumb drive?
                      DR
                      • pakalo
                        • szhengpaper
                          For sell all type of A4 copy paper 80gsm
                          Szheng Paper Box Sdn Bhd Registered no.(ps/136787-p) is known for the Manufacturer and supply of best quality A4 copy paper, we supply mostly A3 paper A4 paper in roll and in ream 80gsm,75gsm.70gsm.You can request for the specification of all the below paper.brightness 100% which is good for all office use.We supply in major international markets and we are a trusted and dependable company to deal with because we render the best of services to our customers worldwide.We are a registered enterprise here and we operate with 100% return policy and delivery is 100% assured after you agree with our company dealing tools.
                          Contact us today for your order at our marketing Email :szhengpaper@rocketmail.com
                          A4 80GSM
                          Double A copier paper $0. 80
                          Paperone copier paper $0. 80
                          Golden Star copier paper $0. 80
                          Laser / Copier Paper $0. 80
                          Xerox multipurpose copy paper-- $0. 80
                          Mondi Rotritrim copy Paper-- $0. 80
                          offset paper-----------------$0. 90
                          A4 75GSM
                          Paperone copier paper $0. 70
                          Golden Star copier paper $0. 70
                          Laser / Copier Paper $0. 70
                          Laser / Copier Paper $0. 74
                          Xerox multipurpose copy paper-- $0.70
                          Mondi Rotritrim copy Paper-- $0. 70
                          offset paper-----------------$0. 80
                          A4 70GSM
                          Paperone copier paper $0. 65
                          Golden Star copier paper $0. 65
                          Laser / Copier Paper $0. 65
                          Xerox multipurpose copy paper-- $0.75
                          Mondi Rotritrim copy Paper-- $0. 75
                          Specifications:
                          Sheet Size:210mm x 297mm, International Size A4
                          Quality: Imported 100% Virgin Wood Pulp
                          Whiteness = 102-104%,Natural White
                          Capability: High Speed Copying100ppm, Laser
                          Capable,Inkjet Capable, Fax Capable.
                          Thickness: 103-110 um
                          Surface roughness TS ml/min: 75-175
                          Surface roughness BS ml/min: 100-200
                          Bending stiffness MD: >110 Mn
                          Bending stiffness CD: >50 Mn
                          CIE whiteness: 148-152
                          Cobb Test: 27-33 g/m2 27-33
                          KEY PERFORMANCE:
                          No jam in photocopy machine
                          No double feed
                          Stay flat after copying
                          Leave no dust in the copy-machine
                          Nice appearance-white and clean
                          Nice touch-smooth and bulky
                          No see through-print both sides
                          Been developed for : Photocopy Mac
                          NOTE: All price is in ( CIF ) means our company takes care of you shipping process to your port so the price includes paper cost ,shipment and insurance.
                          *Port of loading: Dickson sea Sabah,Malaysia
                          *Payment Term: L/C,T/T,WESTERN UNION
                          Minimum Order Quantity: One 20FCL (20ft Container Load)
                          Sample: Buyer pays for sample orders.
                          Delivery Time: Asia 14 working days,Europe 21 working days,America 24 working days and Africa 21 working days.
                          20FCL will be packed as minimum order quantity from our warehouse.
                          PACKING DETAILS:
                          500 Sheets per Ream
                          5 Reams per Box
                          1560 Boxes per container(With Pallet)
                          1600 Boxes Per container( Without Pallet)
                          7800 Reams Total in one 20FCL( With Pallet)
                          8000 Reams Total in one 20FCL( Without Pallet)
                          We look forward to receive your order confirmation and we hope to hear from you as soon as possible.
